Given the importance of the level of track maintenance required for large size N-Digital tracks, NINCO has come up with POWER TRACK BOOSTER CABLES to ensure the perfect transmission of all information to ensure the track workability.
With N–Digital, all the data flows through the track, and if there are damaged connections, oxidized rails or simply a lot of dirt, this can affect the tracks capabilities on larger layouts. Cleanliness of the braids and the rails, and constant current flow on all parts of the track are important, and more so on very large layouts. It is recommended that the following maintenance steps be employed:
[*]Check and clean the cars' braids (change if necessary)
[*]Check and clean track pieces (change if necessary)
[*]On large layouts use the 10314 POWER TRACK BOOSTER CABLES.
Installing the cables:
- Connect to track pieces in the same lane.
- Ensure correct polarity and the direction of play as indicated on the terminal
