Escrito originalmente por M1K3LSLOT en 7 de Octubre del 2007
Hola Rikorocket, he montado motores superslot de 30 k y me a bajado el rendimiento cuando corro con seis coches ¿porque?
hello riko: i have mounted superslot 30k motors. This has lowered my yields when runnig with 6 cars. Why could this be?
Riko porque pasa?
Escrito originalmente por RikoRocket en 8 de Octubre del 2007
Solution - "master-slave" modification.
Limit of powerbase is 3.5 Amperes (this is a bottleneck inside the powerbase - it makes no difference that 2xC7004 = 5 Amperes)
Master slave adds a second powerbase in synchronisation with your original powerbase.
This gives then 7 Amperes. Or if you are a fanatic, +3,5 Amperes for every slave you add. One man in Australia added 5 slaves!
Here are the instructions - sorry they are in english. master - slave 6 car to 6 car powerbase
I also made instructions to use a 4 car powerbase as a slave to a 6 car powerbase - exactly the same effect, costs less money 4 car powerbase slave
This gives you much more power. Incredible power. Unbelievable power. This is like cocaine - once you have done this modification you will never go back
Escrito originalmente por M1K3LSLOT en 8 de Octubre del 2007
No me atrevo con esta modificacion es muy complicada para mi.
I do not dare with this modification is very complicated for my.
Escrito originalmente por RikoRocket en 9 de Octubre del 2007
3 wires? Complicated? No!
It needs good skill in soldering though.
Escrito originalmente por M1K3LSLOT en 9 de Octubre del 2007
Tengo de traducir bien el pot de su modififcación para comprender bien las cambios.
I have to translate well to the post amendment to understand the changes.
