Cuenta Veltas
Cuenta Veltas
Escrito originalmente por Guest ska en 2 de Enero del 2007
Hola
Happy new year, its me again :)
Please can you help me as you have before. This time its my lap counter. It has stopped working. It has worked before, but now it does not
It has all the lights on, but no numbers just "---" I have 2 power leads connected and I reset it a few times but nothing works.
Any ideas would be greatly appreciated
Thanks
Escrito originalmente por Guest allopez en 2 de Enero del 2007
ska escribió:Hola Happy new year, its me again :)
Thanks
Let's see...
1.- Try to unplug and plug in again.
2.- You have the problem in both tracks? If only in one track could be the magnets and the cables around them. Open the switchboard for checking.
2.- I suppose you have pressed start button in the switchboard
3.- You have pitbox or not? In the case you have the pitbox take a look to the switchboard to see if the laps are countered in the display
ok will test now. We run the pitbox. Like i say everything was ok!!!
Hi No it does not work still. The pit box is correct but the lap counter just says ---
Strange
Escrito originalmente por djlutz en 2 de Enero del 2007
Hi again ska, Imagen
Did you check if the PitBox unit is counting the laps or not?
Have your lap counter the inscription of PowerLine?
How far away is the lap counter from the central pitbox unit?
Are all tracks from central pitbox unit to lapcounter PowerLine type?
Did you check the lap counter next to the central unit? Did you get same result?
Could you open the lap counter track and verify if the Power Line conector is well welded? (any pictures?)
Could you show some pictures from the circuit and lap counter position?
See you
Hi djlutz
Thanks for the suggestions I will check and try and report back!
All the best
Escrito originalmente por Guest potato en 2 de Enero del 2007
traduzco para ampliar a los no angloparlantes la posible ayuda para ska
(I'm translating the topic for non-english spokers to help)
Thanks
Hola
Feliz años nuevo, soy yo otra vez
por favor podriais ayudarme como ya hicisteis otras veces? ahora es el cuentavueltas, ha dejado de funcionar... funciono antes, pero ahora ya no
se enciende bien, pero no se ven numeros, solo "---" Tengo dos trafos conectados y lo reseteo varias veces, pero ni aun asi
cualquier idea ayudara
allopez escribió:Let's see...1.- Try to unplug and plug in again.
Veamos
1- intenta desenchufarlo y volver a enchufarlo
2- Tienes el mismo problema en ambos carriles? si solo es en uno, podrian ser los imanes y los cables de alrededor. Abre el panel para mirarlo
2- Supongo que habras pulsado el boton de inicio en el panel
3- Tienes boxes o no? en caso de que lo tengas, echa un vistazo al panel para ver si se cuentan las vueltas en la pantalla
ska escribió:ok will test now. We run the pitbox. Like i say everything was ok!!!
lo mirare, corremos con boxes, como digo, todo estaba bien antes!!!
ska escribió:Hi No it does not work still. The pit box is correct but the lap counter just says --- Strange
hola, aun no funciona. boxes funciona bien [se refieren al conteo de combustible] pero el cuentavueltas dice --- (que nones, vamos)
djlutz escribió:Hi again ska, ImagenDid you check if the PitBox unit is counting the laps or not?
See you
Hola otra vez, ska Imagen
miraste si el modulo de pitbox cuenta las vueltas o no?
como de lejos esta tu cuentavueltas de la central pitbox?
son todas las pistas entre el cuentavueltas y la central de tipo powerline?
miraste con el cuentavueltas junto a la central? paso lo mismo?
podrias abir la pista del cuentavueltas y mirar si el conector power line esta bien [soldado?] (has hecho fotos?)
podrias poner fotos de la posicion del cuentavueltas en el circuito?
nos vemos!
ska escribió:Hi djlutzThanks for the suggestions I will check and try and report back!
All the best
hola djlutz
gracias por las sugerencias, lo probare y os contare
os deseo lo mejor
potato estas enfermo... Imagen
djlutz escribió:potato estas enfermo... Imagen
quien? (guiño) yo? (tic) porque? (espasmo) si... solo intento (tic) ayudar... (espasmo, guiño)
ImagenImagen
y porque aun no tengo el tp, que si no... seria el circuitero, todo el dia "mira, esta es mi sugerencia", o "si, muy bonitas las fotos, pero y si lo desmontas y lo montas asi?", o ya lo peor, spam de pms diciendo "te diseño un circuito? eh? eh? anda, dime que si!"
ImagenImagenImagenImagenImagen
Escrito originalmente por Guest ska en 3 de Enero del 2007
Thank you Potato. I really wish I could speak more Spanish pero para mi es muy difficil para aprender. Cada dia entiendo mas.
Escrito originalmente por Guest potato en 3 de Enero del 2007
ska escribió:Thank you Potato. I really wish I could speak more Spanish pero para mi es muy difficil para aprender. Cada dia entiendo mas.
remember: don't pronounce "potato" like in english, it is poh-tah-toh, just as if you were reading it in spanish... "po" like in police, "ta" like in tantra, and "to", like tokyo
ImagenImagenImagen
yes, it's just me, I'm so weird xD
Well
I fixed it, but I don't really know how!
I moved it nearer the pit box control straight, and it started to work on one lane only. So I moved the magnets and reseated the reed switches.
Then it worked. Imagen
But then. I moved a barrier and it stopped working Imagen
I then swapped a standard straight that was with a small 1/4 size straight and it worked and it still is working.
When I say i swapped them I mean i turned them round so the track previously was:
Curve, Standard Straight , 1/4 Size Straight, pit sections ------and now it is:
Curve, 1/4 Size Straight, Standard Straight, pit sections---------and it works!!!!
Thanks for your help guys and if you have any theories why it works now that would be great to, because although It works I don't know why Imagen
Thanks to all
Escrito originalmente por djlutz en 3 de Enero del 2007
May be a bad Power Line contact....
It would be good to check with a multimeter the continuity of these line.
Think that the lap counter only takes the Power Line signal from one of the two rails. So may be you already have the problem, but you turned the track (unconscious) and now the good rail is that one who gives the signal to the Lap counter.
Thats the Poltergeist Imagen
In Spain we call "Witches" all these irrational things that make electric and electronic things work apparently when they want... to be serious, usually the problem is that it is something too complex or too silly to be pointed, and we fix it or do it bad without knowing, even thinking that we are doing it just in the same way...
in this case, I think djlutz is right, maybe you turned the piece unconscious... just try with multimeter
greets!
Volver a “Sistema SDS”
