NEWS ! NEWS !
NEWS ! NEWS !
Escrito originalmente por Guest dennisko en 19 de Octubre del 2006
Hi, spanish friends!
Here is the guy from Holland again bringing you some inside info.
Yesterday there was a live chat on www.freeslotter.de of two hours with the German importer Jorg Shamuhn and Stefan Wilhelmi (technical service) of SCX (Scalextric in Spain) in Germany.
Here are some nice to know things which evolved from the chat:
-The new DTM set (SCX10030) will come to Hamburg on nov 2nd and will be in stores on nov 7th.
-The renewed (red) guidekeels will be available on nov 10th.
-The upcoming console (planned for 2007) makes new firmware updates possible and has a USB-connection, INTERNET RACING possibillity !!!!, race management, lapcounter, etc. It is said to have enormous possibillities which would have taken way to long to explain during the chat !!!
-Introduction on nov 15th of the Aston Martin
-Introduction on nov 20th of the Seat Leon
-Introduction on nov 25th of the Corvette
-R3 curve is being developped (will come in 2007), no plans yet for R4 curve
-Innerside borders will come as well (2007)
-New Upcoming 2006 quality is better than ever
-There is a new CEO at SCX who's strategy is to make sure that there will be top-quality in 1.analog/digital 2.introduction of new accessories 3.profi-line
-Ghostcar will come on nov 20th and can be used as 1.slotcar (rooflights out) 2.ghost car
In the ghostcar mode you have to drive it for one round and the chip will sense the track, changeovers, etc. Then it can drive on its own and change lanes at random positions. It works with a timer to know where it is. In ghostcar mode it doesn't go into the pit and doesn't use fuel. It reduces the driven speed by 25%.
-Profi-line will come in beginning of 2007. It consists of bearings, tyres, wheels, engines, brake systems, optimised cars, tyre rubbing systems.... and is said to be something really special... something we have never seen before
-Nascar set will be available before christmas
-The new DTM10030 set has been in Germany at the Import (www.JSB-GmbH.de) for 5 weeks now and has been thoroughly tested with no single problem.
-The changeover curve will be slightly redesigned to avoid collissions with the change-blade and will be available as of nov 15th
-SCX promisses new things to be introduced at Nuernberg ToyFair in Germany (approx feb 2007)
-Renewed (SCX10020) Ferrari Pitstop set arrives not earlier than nov 20th
-No changes in frontwheel suspension of which I reported earlier.
Hope you guys appreciate it (although in English)
Greetings Dennis
Olanda
Greetings Dennis
Olanda
Escrito originalmente por cristobal berrios en 19 de Octubre del 2006
alguien que traduzca, gracias por anticipado amigo dennisko
hay que ver que siempre que postea nos hace felices
De nada !
De nada !
Escrito originalmente por Guest allopez en 19 de Octubre del 2006
He utilizado un tractor, ya que es un buen tocho...
¡Hi, amigos españoles! Aquí está el individuo de Holanda otra vez que trae alguna Info desde dentro.
Ayer hubo una charla en www.freeslotter.de de dos horas con el importador alemán Jorg Shamuhn y Stefan Wilhelmi (servicio técnico) de SCX (Scalextric en España) en Alemania.
Aquí están algunas agradables cosas que se desarrollaron en la charla:
- El nuevo sistema de DTM (SCX10030) vendrá a Hamburgo el 2 Nov y estará en almacenes el 7 Nov.
- Las quillas renovadas (color rojo) estarán disponibles el 10 Nov.
- La consola próxima (prevista para 2007) tiene actualizaciones de firmware y tiene una conexión USB, posibilidad de competir en INTERNET!!!! , gestión de carrera, cuentavueltas, etc. Dicen que tiene tantas posibilidades que se necesita más de una charla en un chat para poder explicarlo todo.
- Introducción el 15 Nov del Aston Martin
- Introducción el 20 Nov del Seat Leon
- Introducción el 25 Nov del Corvette
- La curva R3 está siendo desarrollada (vendrá en 2007), no hay planes para la curva R4
- Los bordes interiores también en 2007
- Mejoras en la calidad
- Hay un nuevo CEO en SCX que quiere que la estrategia sea cerciorarse de que habrá calidad superior en 1.analog/digital 2.introducción de los accesorios nuevos 3.accesorios pro
- Ghostcar vendrá el 20 Nov y se puede utilizar como 1.coche fantasma 2.slotcar (sin luces de techo) En el modo fantasma tienes que conducirlo una vuelta y el chip detectará la pista, los cambios, etc. Después puede conducir él solo y utilizar los cambios de carril al azar. Trabaja con un contador de tiempo para saber donde está. En modo ghostcar no entra al pit y no utiliza el combustible. Reduce la velocidad del resto de coches en un 25%.
- La gama de accesorios PRO vendrá en el principio de 2007. Consiste en cojinetes, neumáticos, ruedas, motores, sistemas de frenos, coches optimizados, sistemas del frotamiento del neumático (esto no sé). y será algo realmente especial...algo que nunca hemos visto antes
- El sistema de Nascar estará disponible antes de Navidad
- El nuevo sistema DTM10030 ha estado en Alemania en la importación (www.JSB-GmbH.de) por 5 semanas y se ha probado a fondo sin problemas.
- La curva del cambio será reajustada para evitar colisiones con las guías de cambio y estará disponible el día 15 Nov
- Habrá nuevas sorpresas que se introducirán en Nuremberg ToyFair en Alemania (aproximadamente el Feb de 2007)
- (SCX10020) el sistema renovado de Ferrari Pitstop no llegará antes del 20 Nov
- Ningún cambio en la suspensión de las ruedas delanteras como había dicho antes.
Uff.....Impresionante!!! Ahora sí que sí, esto es la guerra
Ya sí que no aguanto más.....
I'm really excited with these great news dennisko.
Thanks a lot for this excellent info, you are giving us a lot of hope for the next month.
Our VISA cards are ready to burn!!
Escrito originalmente por litus14 en 19 de Octubre del 2006
Nuestro amigo holandés postea lo siguiente:
Ayer estuvo en un chat aleman con el importador aleman Jorg Shamuhn y Stefan Wilhelmi (tecnico service) de SDS en Alemania.
- El nuevo set DTM (SCX10030) estará en hambugo el 02/11 y en las tiendas el 07/11
- La nueva guia roja el 10/11
- La consola (planeada el 2007) tendrá la posibilidad de actualizar firmware y tendra conexion USB, osea multiples posibilidades.
- Aston Martin el 15/11
- Seat Leon el 20/11
- Corvette el 25/11
- La curva exterior (R3) esta siendo desarrollada, la superexterior (R4) no.
- Bordes interiores en 2007
- Nueva calidad de SCX mucho mejor que antes
- Hay un nuevo presidente en SCX que es la estrategia debe asegurarse que allí será de calidad superior en 1.analog/digital 2.introduction de nueva 3.profi-línea de accesorios
- Coche fantasma el 20/11 que puede usarse como coche o como fantasma (supongo safetycar)
En el modo ghostcar tienes que conducirlo una vuelta y el chip sentirá la pista, cambios, etc. Entonces esto puede conducir solo y cambiar al azar. Trabaja con un temporizador para saber donde esta. En el modo ghostcar no usa el combustible. Esto reduce la velocidad conducida en el 25 %.
- Componentes de competicion profesional (?) en 2007. Neumaticos, ejes, etc
- Nascar antes de navidades
- El nuevo set DT; ha sido probado en Alemania por www.JSB-GmbH sin problemas.
- Cambio en curva sera rediseñado para evitar colisiones con el cambio y estara para el 15/11
- SCX promete mas cosas que se veran en Nurenberg ToyFair in Germany (approx feb 2007)
- El nuevo Ferrari Pitstop set (SCX10020) no llegara antes del 20/11
- Corvette el 25/11
Escrito originalmente por olgydan en 19 de Octubre del 2006
Hola amigos españoles,
Aqui el chico de Holanda que os trae información,
Ayer estuve en el chat www.freesloter.de mas de dos horas con el importador aleman Jorg Shamuhn y Stefan Wilhelmi (servicio tecnico) de (Scalextric en España) para Alemania.
Estas son la cosas que comentamos,
El nuevo set DTM (SCX10030) estara en Hamburgo el 2 de Nov y en las tiendas el 7 de Nov
Las nuevas guias, las rojas con el corte diagonal y mas suaves en 10 de Nov.
La consola (para el 2007), tendra un firmware actualizable or conexión usb, con posibilidad de competir por internet, direccion de carrera, cuenta vueltas, tiempos e infintas posibilidades, que estuvimos tratando durante largo rato.
El Aston Martin el 15 de Nov
El Seat León el 20 de Nov
El Corvette el 25 de Nov
Curva R3 para el 2007, no pensada la curva r4
Bordes interiores 2007
La estrategia esta en mejorar la calidad de los productos
El coche fantasma para el 20 de Nov, se podra usar como coche normal, o como fantasma
En el modo fantasma tu puedes dar una vuelta memorizarla y el chip se aprende el recorrido y los cambios. Tambien puede cambiar de carril aleatoriamente. Trabaja con un temporizador. No usara el pit stop y a tu mejor vuelta le descuenta un 25% de la velocidad.
La linea de material pro vendra en el 2007 con material de todo tipo, con cosas muy especiales que jamas se han visto acercando este mundo a la realidad (olgydan:aqui de algo me han hablado, pero esta por ver....)
El set Nascar para Navidades.
El nuevo cambio en curva a partir del 15 de Nov
El la feria de Nuremberg FEB 2007 prometen novedades
Un renovado set Ferrari pit stop para 20 de Nov
No se hara cambios en el eje anterior.
Dennis
Holanda
Dennis
Holanda
Venga !!!! Otro !!!!!!!!!
jajajaja
jajajaja
Escrito originalmente por Guest charmander en 19 de Octubre del 2006
I M P R E S I O N A N T E !!!
haber si es verdad !!!
Hay muchos dedos hábiles por aquí, eh??
Ahora vamos a empezar con los comentarios y discusiones.
Lo de la consola me parece impresionante!! Va a dar mucho que hablar
También me gusta mucho la línea de productos PRO para el digital, a ver si llega pronto en 2007.
Me ha resultado llamativo también lo de los cambios en curva, nos cambiaran los antiguos en el SAT?
Yo si es verdad que van a plantearse el tema de la CALIDAD en serio, me plantearé muy seriamente cambiar o no cambiar a Ninco.
Eso sí ahora hay que hacer realidad todas esas promesas, porque de promesas nos han ido llenando la cabeza desde hace tiempo atrás !!!
Escrito originalmente por Sorjiah en 19 de Octubre del 2006
JAJAJA Nos ha faltado tiempo para traducirlo, anda que no hay ganas de que salgan las cosas
Pues verás que al final lo de los motores nuevos para el sds para principios del año que viene va a ser cierto..
Allopez,
If you are having trouble with the changeover curve, in Germany they will replace them with new ones.
I think in Spain they will do the same, since they give a 2 years of warrenty.
I modified the sharp end of the change-lever, and now I don't have any problems anymore.
Dennis
Allopez,
Dennis
Thanks again Dennis.
You are right with the 2 years of warranty. In my case I'm not having problems with my changeovers, it was only a question in the case someone has those problems.dennisko escribió:Allopez,
Dennis
los retrasos ya llegarán !!!
Yo de todas formas pienso que esto es lo PRINCIPAL !!!olgydan escribió:La estrategia esta en mejorar la calidad de los productos
si es capaz tecnitoys de hacer todo lo que cuenta dennisko, hacer suya la bandera de la calidad, hacer una linea de productos pro en condiciones de competir con ninco (ya no digo slot it porque seria una quimera) y dar una sorpresa mas que no te la cuentan para dejar algo para nuremberg, estaran dando un puñetazo encima de la mesa, y los demas en fila. vamos a ver
Yo tengo que reconocer que tengo buenas sensaciones, por lo menos leyendo los puntos comentados creo que se han fijado en los puntos débiles y eso es positivos. Ahora sólo queda ver si realmente han podido solventarlos correctamente y ver si es verdad que empiezan a llegar los producto al mercado.
Escrito originalmente por victor-maiden en 19 de Octubre del 2006
Por fin,se ha conseguido despues de mucho tiempo de protestas se fijaran mas en la calidad como meta.
Espero que todo vaya bien y que solucionen todos los problemas de la peña,que los mios han sido muchos,por que si lo hacen asi tienen mucho tiempo ganado.
Yo me estaba planteando cambiar de marca,pero si lo que se comenta es cierto y con todo lo que llega,pos va ser que no.
De todas formas yo que ria pensar que una marca como scalextric tenia que dar el puñetazo en la mesa de una vez,mucho han tardado.
Lo de los accesorios pro le verdad que es muy interesante,espero que aqui incluyan unos muelles mas duros para los ejes delanteros.Preparemonos para la gran batalla que esta por venir.
